How do I fix this? Cracks, visible seams in side wall, hinge
Posted: Wed Feb 01, 2023 3:53 pm
Hi! New here, so apologies if any of this is not correct process!
I bought this 'new to me' teardrop and would like to do some restoration.
I noticed some issues where the hinge meets the side wall. See photos below of each side. What's the best way to fix these cracks and the seam? Also, the hinge does not extend past the sidewall. It looks like the previous owner had covered it with tape and I'd like to do something more permanent. I'm considering extending the metal trim under the hinge and replacing the hinge with a slightly longer one, but if there's an easier way then I'm all ears.
Separately, can you tell what material the side wall is? Is it painted wood?
Thank you in advance! Really appreciate any help as I jump into the teardrop world!
