tony.latham wrote:Well, that isn't much of a joint. This is the way I do it:
The wall is glued on two plains to the floor, and pocket-screwed on the inside, and then screwed from the outside horizontally.
Rock solid.
how wide is your camper?
Pmullen503 wrote:The lap joint could work with sufficient fasteners but having some kind of "keyed" joint
like the dado or rabbit joint would not only be stronger but make assembly easier and more accurate.
A good design principle is to let the structure carry the loads. The fasteners should hold the load bearing members in place, not carry the loads themselves.
The galley wall, if properly fastened, would help "hold up" the sides by transferring some of the weight from the side fasteners to the inner wall.
Tom&Shelly wrote:Notice the cartoon appears to show a wall as a single sheet of plywood with the lap joint. Because of the single sheet, a lap joint may have been necessary.
What is the lifetime of a teardrop made with solid ply walls? Might have only been a few years. I don't know.
Folks have complained about condensation in un-insulated tears. Some only built them to test space requirements, camped in them a few times, and then went on to build more permanent tears out of sandwich walls. (Plywood was cheaper in the old days.) (And it was an uphill hike to the one room school; both ways!)
Anyway, my recollection is that the cartoon was made around the start of the forum to show what folks were thinking/doing then. Took a few years for the best ideas to percolate to the top.
tony.latham wrote:how wide is your camper?
60" outside and 56.5" inside. It fits a queen mattress just fine.
Why do you think the older teardrops were heavier?
Foam squeezes.23Sojourney45 wrote:tony.latham wrote:how wide is your camper?
Tony, a queen mattress inside the 56.5? awesome. I was thinking of a queen but didn't know how it would fit mine, there's hope!
