Anyone have preferences on what insulation they used? I have thought foam sheeting insulation but have some extra R11 Owens Corning pink fiberglass stuff in rolls. I know I'd have to compact the roll stuff.
Recommended type?
Pros/Cons?
mikeschn wrote:Yes rigid foam has the higher insulation value.
If you take the fiberglass and compress it, you actually reduce the r-value.
