Gage wrote:My computer must be screwed up. I go to the map and don't see a thing but a blank map with all the states outlined. I'm not going to enter my location every time I go to check out the map. I did it once, that should be enough.
Have a good day.
Gage wrote:Question:How do you move a marker? I should be on R11. If you do the SAT view of the map, you'll see a large swimming pool down a little from my marker on another street. I'm right next door to the left.
curiouswill wrote:Gage wrote:My computer must be screwed up. I go to the map and don't see a thing but a blank map with all the states outlined. I'm not going to enter my location every time I go to check out the map. I did it once, that should be enough.
Have a good day.
I don't think that it would be your computer that is messed up. do you have a slow internet connection cause that may be the reason why the map u see are not totally loaded.
I have looked up your username, zoomed in, and found you just off Stonegate Lane.
Is the location wrong or something?
Return to Threads about the forum!
