Embed photos from your personal albums...
Threads about the forum, forum software, forum features, etc
Postby mikeschn » Mon Mar 21, 2005 8:58 am
You guys that have photos in your personal albums here can now embed them as photos in your message....
for example..
will appear like this:
Hope that helps... :D
P.S. make sure there are no spaces in between the img tags! ;)
Images: 479
Postby SteveH » Mon Mar 21, 2005 9:33 am
Cool! :thumbsup: Thanks Mike.
SteveH
SteveH
Images: 42
Postby Arne » Mon Mar 21, 2005 10:32 am
Mike, is there a command that is used....? I understand what you are saying, but do not know how it would be done...
[img]
I got the img thing in (another item I never noticed before/g/), but what connects it to a photo.... I'm going to post this and see if it instructs me to pick it up....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby mikeschn » Mon Mar 21, 2005 10:36 am
It's very easy arne... go to your personal album and display the photo you wish to embed.
highlight the url and click "edit" ->"copy"
Start composing a message and click "edit" ->"paste"
Then highlight the url in the message, and hit the Img button.
:D
Images: 479
Postby Arne » Mon Mar 21, 2005 11:35 am
test.... got it.... much nicer...... note my ability to catch passing car. something I probably couldn't do if I tried.....
Arne
Mr. Subject Line
Images: 96
Postby Guest » Mon Mar 21, 2005 11:39 am
About Spaces Between The Image Tags.... What I've noticed is... If you have a space in your file name you need to go back and eliminate the space, or put an underscore in that location in the file name itself, or easier yet, type in %20 where a space occurs in your file name to get it to work when using image tags.
Guest
Postby doug hodder » Tue Mar 22, 2005 9:55 pm
Is this the same process I would use to post a photo into my profile? I need to resize my photos as they are all 480 x 640, I think? Thanks in advance. doug hodder :roll:
MMMMMMM
Postby OkieSailor » Thu Mar 24, 2005 10:36 pm
I am going to try this!
Hot dog! Thanks for the final piece of the puzzle. :twisted: Now no one will be safe!!
Yes OkieSailor is an Oxymoron!!
OkieSailor
Postby asianflava » Thu Mar 24, 2005 10:47 pm
Looks like you are missing a bracket on the closing IMG. It took me several tries. It looks like you are close though. Just hit the Img button on top, paste the link then hit "Close Tags". That should work out for ya
asianflava
Postby Steve Frederick » Thu Mar 24, 2005 10:52 pm
Okiesailor, I fixed the tag for you!! :thumbsup:
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Photos
Postby OkieSailor » Thu Mar 24, 2005 11:00 pm
I think what threw me off was the label on Mikes photo. I finally figured out that the img on the end of his photo was part of the label and not a command.
Thanks for the help Steve.
Thanks for the help Asianflava. I cooked beef curry with rice for supper tonight. Found a great curry mixture at a local Oriental supermarket --$3.29 for 16 oz of curry mixture (size of a one pound can of coffee).
MMMM Good. :D
OkieSailor
http://www.mikenchell.com/forums/album_personal.php?user_id=
Postby billnut » Mon Nov 07, 2005 7:44 pm
Testv
Grandpa's are just Antique little Boys !
billnut
Postby billnut » Mon Nov 07, 2005 7:45 pm
:cry: Gerr it didn't work
Bill :x
Edited by Dean:
Bill click on the edit button of this post and look at what I did to the text below on the next line.....
Note: when you look at what I did, it appears that the [/img] tag at the end is on the next line and there is a space between id=3695 and [/img].
There isnt, it just looks that way because the string of text for the url was so long...
Hope this helps.
billnut
Postby mikeschn » Mon Nov 07, 2005 7:50 pm
Bill,
It's not hard... copy the url from your album...
paste it here
http://tnttt.com/album_ ... ic_id=3819
then put an [img]in%20the%20front%20and%20an[/img] in the back like this...
and up pops a picture... (Be sure there are no spaces inbetween the img tags...)
Images: 479
Postby Guest » Mon Nov 07, 2005 7:51 pm
Bill,
Want some help?
You're on the right track...
Just tell me which picture you want from your album and I'll show you in your post...
(Whoop, Mike beat me to it)
Guest
Return to Threads about the forum!
