How to edit thread Title???
Threads about the forum, forum software, forum features, etc
Postby WizardOfOdds » Tue May 26, 2015 12:52 pm
I see how to edit a previous post (using the "edit" button while signed-in and viewing
one of your own posts), but how do you edit the title of the thread you created (not the
subject line of the post, rather the title of the thread as it appears in the thread list).
I've seen others changed, does it require special edit privileges?
WizardOfOdds: Chalet shaped rag roof clam shell TIER drop for 4 cylinder tow
Tip Top Tier Drop thread http://www.tnttt.com/viewtopic.php?f=5&t=56232
Unusual Designs thread http://www.tnttt.com/viewtopic.php?f=5&t=64495
Tale of 2 Trailers thread http://www.tnttt.com/viewtopic.php?f=35&t=61451
WizardOfOdds
Images: 44
Re: How to edit thread Title?
Postby PaulC » Tue May 26, 2015 7:26 pm
You should be able to see the "edit" button in the top right hand corner of your post. I am assuming that when you, as the author of the thread, hit that button you should be able to edit the title as well as the body of the thread.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Location: Laura, Souther Flinders Ranges, South Australia
How to edit thread Title-first post
Postby tac422 » Tue May 26, 2015 8:33 pm
I believe you have to edit the subject in the very first post to change the title...
tac422
Images: 220
Re: How to edit thread Title???
Postby WizardOfOdds » Tue May 26, 2015 11:13 pm
Yes, that does work... Thank you. I hope this helps others as well.
I tried this before starting this thread, but only looked at the "Preview". The "Preview" seems to retain the old title, but once I did a "Submit", then the title changed.
As a test, I just changed the title to have 3 question marks rather than one.
WizardOfOdds
Images: 44
Return to Threads about the forum!
