Design Library - we need your files...
Threads about the forum, forum software, forum features, etc
Re: Design Library - we need your files...
Postby imakerux » Fri Jul 01, 2016 1:29 pm
More????
Wanderer10.pdf
(796.55 KiB) Downloaded 347 times
Profile-Superleggera.pdf
(87.97 KiB) Downloaded 324 times
imakerux
Postby imakerux » Fri Jul 01, 2016 1:33 pm
Here is another two?
widget6-nesting.pdf
(153.91 KiB) Downloaded 323 times
widget6-geometry.pdf
(175.25 KiB) Downloaded 311 times
imakerux
Postby mikeschn » Fri Jul 01, 2016 3:52 pm
Awesome, that's exactly the kind of files I am looking for...
Besides the PDF's does anyone have any dxf's? or zip files?
Images: 479
Postby R. W. Alexander » Fri Jul 01, 2016 6:57 pm
Here are a few zip files that I have.
Profile-Ultralight.pdf
(90.54 KiB) Downloaded 324 times
pico-light-1-dxf.zip
(419.56 KiB) Downloaded 278 times
cubnewh2-dxf.zip
(89.06 KiB) Downloaded 287 times
R. W. Alexander
Images: 77
Postby R. W. Alexander » Fri Jul 01, 2016 7:08 pm
I can only add 3 files per post. here is a DXF of the ultralight to go with my previous post. I am at this time reworking the Ultralight for a foam build. And I will post the detailed DXF drawings for it, if you want it.
ultralight.dxf
(31.65 KiB) Downloaded 287 times
R. W. Alexander
Images: 77
Postby imakerux » Fri Jul 01, 2016 9:29 pm
I found another hard drive!
campster12-profile.pdf
(72.85 KiB) Downloaded 314 times
campster12.pdf
(274.49 KiB) Downloaded 301 times
imakerux
Postby imakerux » Fri Jul 01, 2016 9:34 pm
More?????
cubnewh2.pdf
(60.97 KiB) Downloaded 281 times
cubnewl.pdf
(46.35 KiB) Downloaded 295 times
chassis-superlight-5ft-welded.pdf
(330.77 KiB) Downloaded 301 times
imakerux
Postby imakerux » Fri Jul 01, 2016 9:39 pm
And even more!
dinette2.pdf
(77.99 KiB) Downloaded 297 times
dinette.pdf
(60.8 KiB) Downloaded 301 times
imakerux
Postby imakerux » Fri Jul 01, 2016 9:54 pm
I'm on a roll!!!!
standie_clamshell_profile.pdf
(27.49 KiB) Downloaded 308 times
nkm2.pdf
(67.22 KiB) Downloaded 291 times
grumman-8ft-prof.pdf
(41.22 KiB) Downloaded 291 times
imakerux
Postby imakerux » Fri Jul 01, 2016 10:15 pm
Looking for some more????
I have some old drives that might have some more, but it might take a while.
ccar-geom.pdf
(93.13 KiB) Downloaded 304 times
ccar2.pdf
(131.6 KiB) Downloaded 285 times
tdslplans.pdf
(36.56 KiB) Downloaded 291 times
imakerux
Postby Kim Armstrong » Sat Jul 02, 2016 5:10 am
aggie79 wrote:Mike,
If all else fails, I have printed copies of several of the plans that I could scan to PDF, TIFF, JPG, etc.
mikeschn wrote:If you've downloaded any files from Andrew's Design Library, please upload them to this thread. I'll put your files on that page! Click on the Upload Attachment tab below...
It may be me, but I don't see the tab. Am I looking at something incorrect?
Andrew also did some profiles for designs not in the design library. I did find that I had PDFs of the Shasta profile that he did. If interested, please let me know.
Take care,
Hi Tom, what other profiles have you got that Are not in the design library? Thanks
Kim Armstrong
Postby aggie79 » Mon Jul 04, 2016 3:24 pm
Here are some of the PDFs I've found:
shasta trailer profile.pdf
Shasta Trailer profile (standy)
(27.1 KiB) Downloaded 304 times
shasta profile measurements.pdf
Shasta Trailer profile with grid measurements
(95.35 KiB) Downloaded 306 times
Profile-Cub.pdf
Cub profile
(87.88 KiB) Downloaded 309 times
Postby aggie79 » Mon Jul 04, 2016 3:29 pm
Here are a couple of graphics Andrew did to show dimension for a torsion axle.
Postby bathloco » Mon Jul 04, 2016 4:21 pm
Some more files :)
2 plus 2
2plus2H-dxf.dxf
(1.8 MiB) Downloaded 262 times
2plus2H.pdf
(398.52 KiB) Downloaded 297 times
2plus2.pdf
(162.13 KiB) Downloaded 243 times
bathloco
Postby bathloco » Mon Jul 04, 2016 4:31 pm
Widget
widget6-hftrailer.pdf
(59.06 KiB) Downloaded 236 times
widget6-general.pdf
(88.99 KiB) Downloaded 234 times
widget6-chassis.pdf
(51.95 KiB) Downloaded 223 times
bathloco
Return to Threads about the forum!
