Staying logged in
Threads about the forum, forum software, forum features, etc
Staying logged in
Postby QueticoBill » Sun Jul 23, 2017 8:21 am
I had stayed logged in for several years but past few weeks it seems I get logged out frequently. In fact, I was logged in when I clicked new post for this thread and it said I had to log in to post. Likewise, I can he logged in and if I click on a link to a build thread in someone's signature, I'm logged out. Is it just my device or are others having issues with this?
Thanks!
QB
QueticoBill
Images: 22
Re: Staying logged in
Postby lrrowe » Sun Jul 23, 2017 9:20 am
No problems here.
Bob
lrrowe
Images: 439
Postby MtnDon » Sun Jul 23, 2017 2:55 pm
If my memory is any good, others have posted, that they were having the same problem. Sadly I don't recall if they posted a solution. I do find that when I switch to one of my other access devices I have to login with the new device. Then when I move to another I have to login with the next device. But I've not had a problem when continuing on the same device.
MtnDon
Images: 24
Postby MtnDon » Sun Jul 23, 2017 2:57 pm
I searched and found this thread... viewtopic.php?f=26&t=60258&p=1174448&hilit=login+problem#p1084521 I didn't read any; I'll leave that to ya'll with troubles.
MtnDon
Images: 24
Postby QueticoBill » Sun Jul 23, 2017 3:40 pm
MtnDon wrote:I searched and found this thread... viewtopic.php?f=26&t=60258&p=1174448&hilit=login+problem#p1084521 I didn't read any; I'll leave that to ya'll with troubles.
Thanks. At least it's not new and I'm not the only one without a solution. Odd that it's a new occurrence, and no other changes I know of.
QB
QueticoBill
Images: 22
Postby working on it » Mon Jul 24, 2017 2:06 pm
There might be a time factor involved...my longer posts always require me to use my computer notepad to save what I've written, just in case it all goes away during a preview or submit failure. I used to use the saved draft feature, until it also started dropping my info, and requiring me to log back in. I've had this occur for 3-4 years, and recently had similar problems on Expedition Portal, so it might have something to do with my local ISP. Just like at work, before I retired, I have to develop and use "WORK AROUNDS" to get anything posted. At work, it was two different IT teams not on the same page, at home, maybe just my luck with computers?
2013 HHRv "squareback/squaredrop", semi-offroad, 4x8 TTT, 2065 lbs
  • *3500 lb Dexter EZ-Lube axle, w/brakes, 3000 lb. springs, & active-progressive bumpstops
  • *27x8.5-14LT all-terrain tires (x 3) *modified Weight Distribution system for single-beam tongue
  • *LED lighting, triple fans, Pioneer stereo *A/C & 110vac heat, Optima AGM, inverter & charger(s)
  • *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill
  • *zinc/stainless steel front racks *96"L x 6"Dia. rooftop fishing rod/reel carrier
156212148599156215
working on it
Images: 449
Postby 2bits » Fri Oct 06, 2017 10:05 am
Check time zone settings then learn to love it like me :(
Thomas
2bits
2bit Member
Images: 16
Postby 2bits » Fri Oct 06, 2017 10:06 am
Using my phone works because it uses my cell signal and not my sattelite connection, no way to resize photos for uploading tho
Thomas
2bits
2bit Member
Images: 16
Return to Threads about the forum!
