V-twin mini bike
Re: V-twin mini bike
Postby noseoil » Wed Mar 16, 2022 5:43 pm
Making a little progress again on the bike, finally. The back-ordered parts should be arriving soon. For now, here's a mock-up of the rear swing-arm for the back end. Drilled a 7/8" tube into a 1" tube for the bushing joint, then a 5/8" bolt goes through the bushing for the pivot point. Should work well enough, but it's overkill, as usual. The 7/8" will be welded in place.
168547
168548
137905
noseoil
Images: 669
Postby noseoil » Fri Mar 25, 2022 9:25 am
Working on the clutch & jackshaft. These two items are critical for good transmission of the power to the rear tire. Alignment & center-line distance are the two things which need to be correct so it doesn't eat belts & cause too much friction.
The plates needed to hang the jackshaft for alignment & strength.
168607
Here's the clutch, engagement is at about 1800 rpms & I don't want a "hard" shift. It may need a bit of adjustment so it's soft enough to not pull the front end up under hard acceleration.
168606
137905
noseoil
Images: 669
Postby twisted lines » Fri Mar 25, 2022 12:22 pm
Don't know how you intend to use this beast, but this is where I would.
100 miles.
I think you may need a Check point for a refill. :lol:
Racking up; And Rapin foam
twisted lines
Postby noseoil » Sat Mar 26, 2022 9:16 am
Looks like a great place to do a test run! That might work, but the debut will probably be at this year's Run To Raton.
A bit more time on the build, still setting up the clutch, jackshaft & geometry for engagement & run-up to speed. Here's the location of the jackshaft, it sits behind the motor & uses the same mounting plate to keep alignment & the correct distance between the clutch & driven pulley. It's called a CVT, or constantly variable transmission. Subaru, Nissan & some other manufacturers use it, along with Polaris & a bunch of other UTV's.
Here's the rear view with parts assembled & alignment being checked.
168647
The side view of the clutch & driven, it needs 10.990" from the center-line of the motor to the center-line of the driven member. As the rpm's increase, the front clutch tightens of the belt & the driven member expands to give about a .87:1 final drive (12% over-drive). Final output will be at 3.21:1 or "about" 70 mph.
168648
https://www.youtube.com/watch?v=Mn92P4j ... M&index=13
137905
noseoil
Images: 669
Postby tony.latham » Sat Mar 26, 2022 9:21 am
That's some serious fabrication skill there, Tim. :thumbs-up:
Postby noseoil » Sat Mar 26, 2022 5:47 pm
Thanks Tony, there's a lot of trail & error involved in this one, but so far so good (not too bad on errors, at least yet).
I drilled & located the jackshaft bracket, cleaned it up a bit & made sure it's all aligned for later, when it starts to get assembled into an actual bike. This is the basic engine & drive-train setup, it could go into a go kart, mini bike (this application) or a boat at this point. Moving along slowly...
168654
137905
noseoil
Images: 669
Postby bdosborn » Sat Mar 26, 2022 6:06 pm
noseoil wrote:Here's the clutch, engagement is at about 1800 rpms & I don't want a "hard" shift. It may need a bit of adjustment so it's soft enough to not pull the front end up under hard acceleration.
You might need some wheelie bars if it does. :lol:
Images: 777
Bent tubing for the frame
Postby noseoil » Wed Mar 30, 2022 8:34 am
I used a friend's tubing bender yesterday for the frame members. He has a shop here in Raton & builds trikes, show bikes & paint. Nice to have friends who share a passion for building things. The frame pieces need to be cut to length, dressed on the ends for fitting & then welded in place for assembly. still plenty to do bet it's moving forward.
168661
137905
noseoil
Images: 669
Postby Pmullen503 » Wed Mar 30, 2022 9:45 am
I'm really enjoying watching the progress on this project. Keep posting updates!
Pmullen503
Images: 67
Postby noseoil » Fri Apr 01, 2022 8:54 am
A little more work on the frame.
168664
137905
noseoil
Images: 669
Postby noseoil » Sun Apr 03, 2022 8:28 am
Redid a bit of framing (changed the height of the front end), but this is what it will be once the rest is done.
168748
137905
noseoil
Images: 669
Postby bdosborn » Sun Apr 03, 2022 8:43 am
Did you make the head tube angle a little less steep? It looked pretty steep in the mock-up, I was wondering how well the front shocks would work.
Images: 777
Postby noseoil » Sun Apr 03, 2022 9:58 pm
Yes, I should have ordered the 29" set, but instead got the 31" so I made a bit of a change to drop it a little bit. Trail dimension is just over 4" so it will be a relatively slow turner, but good at speed. Definitely a challenging build, but it's fun.
137905
noseoil
Images: 669
Postby bdosborn » Mon Apr 04, 2022 8:19 am
I'm always amazed by how different the things I build turn out from what I thought they would be. But I'm with you, that and the challenge is the the fun part.
Images: 777
Postby noseoil » Tue Apr 05, 2022 10:53 pm
Decided to see if things fit together correctly. So far, so good. Will need a different air filter, had to cut the plastic shroud to slide things in place, but things line up well enough...
168782
168780
168781
137905
noseoil
Images: 669
