butler pickup camper
Postby dwgriff1 » Mon Oct 02, 2006 10:20 pm
Has anyone built from these plans?
http://www.butlerprojects.com/other/tru ... /index.htm
dave
dwgriff1
Postby PresTx82 » Thu Oct 05, 2006 8:50 pm
Very interesting!
Mark
El Paso, Texas
PresTx82
Postby dwgriff1 » Thu Oct 05, 2006 11:19 pm
If I am going to pull my little tear with a pickup, I might put a camper on the pickup to hold the jacuzzi.
Shucks if I were doing it again, I might build a 3 bedroom tear with a sauna.
This camper and topper has some real interesting design ideas. I really like the weight. Seems like it might work on a tow rig, somehow.
dave
dwgriff1
Postby cracker39 » Fri Oct 06, 2006 7:20 am
Roomy topper? I'd think so. Camper? It doesn't look like there is room inside to do much camping...maybe sleeping on the floor. I'd rather build a version of the Compact as a pick up camper if I were going that route.
Dale
cracker39
Images: 233
Postby dwgriff1 » Fri Oct 06, 2006 8:40 am
You miss the point.
Those nice round corners are not going to work on a tear, or would they?
Could you build a tiny trailer, from wood (or alum for that matter) something like an old airstream?
I borrowed a freind's 28' Avion a while back. It pulled a LOT easier than my 22 square box. Those round corners had to have something to do with that advantage.
dave
dwgriff1
Postby cracker39 » Fri Oct 06, 2006 10:51 am
dwgriff1 wrote:You miss the point.
dave
Probably not from those materials. Shaping hi-density foam and applying fiberglass over it might work. If I were to build another TTT, I'd shape the front end and roof like the Award trailers.
Dale
cracker39
Images: 233
Re: butler pickup camper
Postby BrandonWhite » Sun Oct 06, 2013 8:13 am
I know this post is really old, BUT...
Can someone please explain how the builder created the rounded front corners on this camper? I think this would look cool on a small travel trailer. Something similar to an Airstream.
http://www.butlerprojects.com/other/tru ... r/more.htm
http://www.butlerprojects.com/other/tru ... ex_001.jpg
BrandonWhite
Postby Larry C » Sun Oct 06, 2013 8:47 am
It looks like it was done with strips over station forms, but I don't understand the wavy lines? I would think carved foam would work too.
Larry C
Images: 78
Postby S. Heisley » Sun Oct 06, 2013 10:23 am
I like it and those rounded corners would be perfect on a homemade raindrop-style teardrop. :thumbsup:
Maybe those wavy lines are where cracks that were filled with epoxy filler? :NC
I'd be tempted to do this one as a part foamie-style, to make it even lighter and easier to lift on and off.
There are advantages to trailers and advantages to truck campers.
A trailer may have a few more advantages than a truck camper; but, the eye is in the beholder and his needs. :yes:
Images: 488
Postby cracker39 » Sun Oct 06, 2013 2:39 pm
S. Heisley wrote:There are advantages to trailers and advantages to truck campers.
I had a 10’ slide-in truck camper back in the 1970s and 1980s. It was a deluxe model that slept 6, had a toilet room with hand-held shower, gas/electric fridge, gas stove with oven, furnace and 6 gallon hot water heater. It had nearly all the conveniences anyone would want. But, compared to my PopTop, which doesn’t have most of those features, I think I prefer the PopTop since I have no kids traveling with me now. With the bed folded away into the couch, it has as much floor space as the pickup camper did. I listed two related pros and cons for the two different types of campers based on my experiences.
Pickup Camper over Tiny Travel Trailer
Passengers can safely ride inside the pickup camper. My wife and kids rode in the camper most of the time where they could move around or take naps if they wanted to. My wife could even prepare sandwiches for lunch and hand mine to me in the cab of the truck through the connecting windows.
Ii is illegal in many states for passengers to ride inside a travel trailer while moving and darned unsafe in any state.
Tiny Travel Trailer over Pickup Camper
It is Easy to unhook and leave trailer in the camp site while using the tow vehicle to travel around shopping or sight seeing.
It is a lot of work to remove camper from the truck bed (and I’ve done it) to travel around (assuming the camper has jack stands attached and mine did) and inconvenient to prepare camper for driving around if left on the truck (disconnecting water and electric lines, putting away dishes utensils, etc.).
And I’d sure like to know how those compound curves were achieved too.
Dale
cracker39
Images: 233
Postby Laredo » Sun Oct 06, 2013 11:10 pm
BrandonWhite wrote:I know this post is really old, BUT...
Have you got access to one of their books? I lent my copy of the book about building the camper to one of the boys ...
I believe the directions for that camper are in one of the "One Sheet of Plywood" or similar books by Butler.
In metalwork the easy way to do that is with a series of thin pieces stacked atop one another, and as they rise they're counterbalanced
(think a stack of dominoes or pennies going up at an angle). Might be able to do something similar with layers of ply cut so there's an
arc on the edge; have to experiment with whether you'd do better running the arc vertically / horizontally.
Get hold of some corrugated cardboard and cut some pieces for a mockup, and see if it works in your hands.
Laredo
Postby hugh » Mon Oct 07, 2013 6:30 am
I had at one time built a 2 person kayak using wood and foam. The pieces of wood that needed to be bent were done with the aid of steam from a kettle. Once they were thoroughly steamed if I recall I used brass screws and waterproof glue to keep the shape
hugh
Images: 11
Postby angib » Mon Oct 07, 2013 11:10 am
BrandonWhite wrote:Can someone please explain how the builder created the rounded front corners on this camper?
Well, it took them less than 500 hours of work to get them rounded and smooth, but not much less.
Do you still want to know how it's done?
angib
5000 Club
5000 Club
Images: 231
Postby DrCrash » Fri Dec 12, 2014 8:10 pm
Actually I would like to know as I am leaning towards doing the same 16 inch curve on a new trailer I have been drawing up.
I purchased butlers plans for this hoping to get insight on how it was done but be warned he got 45 bucks from me and they are not plans. He advertises 33 pages of drawings, pictures, and detailed how to. I received 12 pages and there is no how to.
It's just some pictures and how you could possible make a camper or topper .
And nothing on the curve at all.
Do not waste your money buying these plans. And yes I did email Mr. butler " Paul" and he was about as helpful as feathers on a rhino.
any hints or tips would be appreciated..
Thinking thin strips nad fiber glass
DrCrash
Images: 51
Postby pchast » Fri Dec 12, 2014 9:57 pm
Perhaps an exercise ball for a form? Read somewhere about landscape balls
being used and cut into quarters. I think here on a metal motorcycle trailer...
Several possible methods. :thinking:
pchast
Images: 96
