Propane tank wood stove
Postby Osage Outlaw » Mon Jan 11, 2016 5:02 pm
Hello, I'm new to this site. I found it while researching for a camper build I'm planning on starting in late spring. Anyway, since this seems to be a DIY crowd I thought I would share a recent project I just finished. I made a small wood stove out of 2 propane tanks, some old wrenches, a hammer head, and 2 lawnmower bagger frames for the stand. I have an insulated 8' x 24' workshop in my garage. I have been heating it with electric heaters. I make wooden longbows and have a lot of scraps left over. I thought it would be nice to heat my work shop with the scrap wood. I didn't want to cut a hole in my garage wall so I got a stainless steel plate and ran the 3" exhaust pipe chimney out the window. I am taking the stove down during the warm months. My fire wood pieces are around 2" x 2" x 6" long. A small fire keeps my work shop at 70 degrees.
I started out with nothin' and I still have most of it left.
Osage Outlaw
Re: Propane tank wood stove
Postby Kaz » Mon Jan 11, 2016 5:11 pm
Sweet, looks like a pretty good us of old parts. Well Done. Probably be great for small cabin or ice fishing shanty too. :D
Kaz
Kaz
Images: 121
Postby Fenlason » Mon Jan 11, 2016 6:26 pm
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Tour de Post Yellow Jersey
Images: 221
Postby blentz » Tue Jan 12, 2016 8:30 pm
Love it! Thinking outside the box.
blentz
Postby Osage Outlaw » Tue Jan 12, 2016 11:45 pm
Thanks. I used it today and burned mostly osage. It got a little warmer in there than I like it to be. I was in a T shirt and sweating. I would turn on my home made air filtration unit for a minute to circulate the air.
Osage Outlaw
Postby razorback » Wed Jan 13, 2016 9:32 am
Very Cool !! I mean Very HOT !!
Larry
razorback
Postby Tomterrific » Wed Jan 13, 2016 9:53 am
I like small stoves. I like hand made. I like your handmade stove. Good design and good looks. The door is just heavy flat sheet so do you feel it may warp?
Thanks,
Tomterrific
Postby Osage Outlaw » Wed Jan 13, 2016 8:22 pm
Tomterrific wrote:I like small stoves. I like hand made. I like your handmade stove. Good design and good looks. The door is just heavy flat sheet so do you feel it may warp?
Thanks,
I don't think it will warp. I extended the door away from the tank a couple inches so the fire isn't right up against it. I'll keep an eye on it and weld on some braces if needed.
Osage Outlaw
