Kidde Fire Extinguisher Recall
Postby Bigwoods » Thu Dec 28, 2017 12:31 am
Don't know where I heard this but Kidde is recalling millions of extinguishers with plastic handles. Mine was a Lifesaver model about 7 years old. You just go to web site and there is a number to call. You want to have Model number and numbers printed on the cylinder and if it is a recalled unit you will get a safer model sent to you. Never know when you might need on that works. :campfire:
Greg in Northern Minnesota
Bigwoods
Images: 103
Re: Kidde Fire Extinguisher Recall
Postby working on it » Thu Dec 28, 2017 1:01 pm
Looks like I'll have to check all of mine...I have 10 in all, all Kidde, varying from 2 to 10 years old. Probably need to replace some anyway.
  • 2013 HHRv,"squareback/simple" TTT, semi-offroad? 4x8, 2000+ lbs travel weight
  • featuring:
    • 3500 lb Dexter axle,
    • 27x8.5-14LT tires,
    • LED lighting,
    • A/C & heat,Optima AGM battery,
    • extended-run 2500w generator,
    • Coleman dual-fuel stove & lantern
  • 147697148333125895
  • 148599148106
working on it
Images: 427
Postby michaeln » Thu Dec 28, 2017 7:38 pm
Thanks for the tip. I went through the process and found my 1984 (!!!!) Kidde Fire Away 110 to be not affected. Probably ought to replace it though, had no idea it was that old.
michaeln
