Tom&Shelly wrote:For those who charge their camper battery from both the TV while driving, and also shore power via a converter (such as in the PD4045) when camping, and have a battery cutoff switch, do you wire your switch to cut off the battery from both possible sources, just the converter, or some other way? I can see the argument for either way, as the TV can be taken off line simply by unplugging the trailer cable. But someone like me might forget how I'd wired it.
Also, connecting the TV battery to the camper battery via the auxiliary wire in the cable (with 30 A fuses at either end), it appears the converter would charge the TV battery as well as the camper battery if one were at a site with shore power, and left the trailer cable plugged into the TV. Any issues with that? I recognize it's not the best thing to keep both batteries in parallel for too long (more than a few days), but, of course, they are connected in parallel for the duration of a drive, with the TV's alternator charging both. How about leaving the batteries connected overnight?
Thank you for your thoughts.
Socal Tom wrote:Tom, the factory jeep 7 pin harness is available on amazon https://smile.amazon.com/gp/product/B00 ... UTF8&psc=1
The instructions are set up for the layman to perform the installation. It even has the provisions for a trailer brake system. All the wires, mounts etc are there. That's what I did, by the time you buy all the parts you are just about at that price anyhow.
Tom ( also)
S. Heisley wrote:Some electrical items may continue to drain the battery even when they are turned off. Also, having a battery disconnect will prevent drains from possible shorts. A battery disconnect can be especially helpful when the trailer is in storage. If done right, a battery disconnect may also help protect your controller, if you have one. However, it all depends on how you have everything wired and connected. Many things are possible. Check the way each item that you are wiring works. ...My two cents worth. (And, of course, always protect with fuses.)
Dale M. wrote:Even with buying the JEEP/MOPAR 7 pin harness kit, I would suggest that you add disconnect relay for the 12 volts to the TD if harness does not have one....
Dale
Users browsing this forum: No registered users and 23 guests
