Thanks for all the replies to my Brainstorm or Brainfart post.
Yesterday I purchased an Optima Yellow top and an inverter. The inverter instruction said a 20' extension cord could be used....Right now I happen to have a 25' indoor/outdoor 12 gauge cord on hand.
So ran a test last night. Battery to inverter. Got a green light on inverter and fan ran smoothly. Plugged in extension cord to inverter and then to the shore inlet on td. Turned on small fan, turned on dvd player. All ran good, no cords got hot or anything. All is good..................
Now when I hook to shore power my circuit testers light up for the "correct" setting. That's two lights on at the last reading.
For the heck of it I used my two Sperry circuit testers to check my GFCI outlet and regular 3 prong outlet in the td with the new battery/inverter set up. Now the bottom reading had all three lights lit. There's nothing on the chart to tell you what this means.
Everything ok to run and proceed????? or is this a concern????
thanks in advance,
Barb
