Richard Grotto wrote:So then run the ground wire (the generator had a screw dedicated to this) to the frame of the trailer?
saltydawg wrote:Richard Grotto wrote:So then run the ground wire (the generator had a screw dedicated to this) to the frame of the trailer?
The cord you use should be fine.
just make sure you run a wire from the plug ground connection on the trailer to frame.
btw all this assumes your wiring the trailer for power if your just using cords don't worry about it.
usmc70_14 wrote:Soooo now I'm confused with my build .. Not to hijack the thread but this is what I'm doing...
4 outlets in trailer leading to breaker panel. White wires go on the stock bus bar inside . In braaker box, I have installed a serperate bus bar that all of the 4 (outlets) grounds go to. That bus bar is then grounded to a screw on the outside of the box, to the trailer. Making sure I've removed the paint on the frame.
Am I wrong or this is correct?
Sent from my SM-G955U1 using Tapatalk
Richard Grotto wrote:would this also work If I ran a wire from the negative of the battery to the frame?
saltydawg wrote: do need the frame to be grounded, but do not bond the neutral and ground.
MickinOz wrote:But my electrical son tells me that any bonding between neutral and ground must be up stream of the RCD/ELCB/GFCI and if the earth and neutral were bonded at the trailer the RCD back at the generator would not work as intended.
At least, I think that's what he said.
