WOW Guy's. Thanks for all the input!!!
I have already installed the spars and frame...I think its at 14.5"... I better check it when I get home.
Thanks again!!!!
Mk
madjack wrote:MK, check that your framing is at least 1.25 or better so as to have enough "meat" for the mounting screws...3/4" will be "too much not enough"(cajun slang)...
Now, I just need to cut out headliner without a router.
toypusher wrote:MK,Now, I just need to cut out headliner without a router.
Unless you have a very long bit for your router you will have to cut from the inside. Hope you have a good full-head cover and an even better dust mask or respirator!!
rbeemer wrote:You can drill 1 hole in each corner and use a jig saw or a hand saw to cut the hole
Mary K wrote:rbeemer wrote:You can drill 1 hole in each corner and use a jig saw or a hand saw to cut the hole
Yup, Thats perdy much how how I been cutting big holes all along.
Mk
toypusher wrote:Be careful when doing this. If you use too course a tooth blade or push a little too hard you can get some unwanted tearout or separation from the roof spars. JMO!
Mary K wrote:................
Wish I had a roto-zip thingie.
Mk
Mary K wrote:toypusher wrote:Be careful when doing this. If you use too course a tooth blade or push a little too hard you can get some unwanted tearout or separation from the roof spars. JMO!
That's good information. Thanks. I'm thinking about using a hand saw to cut it out. I'll have more control and not have a power tool over my head
Mk
