angib wrote:Anyway, with a trailer, when you apply the brakes, aren't all the other lights meant to pulse in time with the turn signals?
I thought that was how they were designed.
Andrew
Leon wrote:Not ALL the lights, just the brakelights.
greasywheats wrote:Ok- an update on my tail light wiring soap opera. Dug around in my Nissan Pathfinder and found that uHaul had already installed a 3-to-2 wire tail light converter when they installed my 7/4 pin connector.
So, I took my tail light units (wesbar) out and attached them with alligator clips directly to the connector pins on the vehicle connector and got the same problem (no right blinky when the brake is engaged, but left blinky does work when brake is engaged).
So I feel better that its not the wiring on my trailer- either the tail light converter is busted, or ...uhh.... I need a whole new truck!
