Two questions...
Re: Two questions...
Postby 48Rob » Mon Jun 16, 2014 6:19 am
This is the unit I have;
http://www.powerstream.com/battery-isolator.htm
Bruce,
You're right, I wasn't thinking about that for the typical tow car/rv setup where the second battery is in the trailer.
(my second battery is 6' behind the first, but is still on the truck)
I am able to start the truck with the second battery because I have massive cables supplying the inverter, which are capable of handling the current needed by the starter motor.
Rob
48Rob
Postby bdosborn » Mon Jun 16, 2014 7:13 pm
I looked at that one and almost got it except for the 1 amp relay holding current. The PV panels on our trailer would cause the relay to combine and the 1 amp overhead is a pretty hefty drain on a typical teardrop size PV system. The Yandina only has 0.150 A overhead current. It's all about application; the powerstream works great in yours, the Yandina works great in mine. :goodmorning:
Images: 777
Postby 48Rob » Wed Jun 18, 2014 5:19 am
Bruce,
Agreed, and I learned something new! :thumbsup:
I didn't even consider that when choosing mine, but I can see how a full amp draw would make it a poor choice for solar...
Thanks!
Rob
48Rob
Users browsing this forum: Google [Bot] and 3 guests
