power converter charger?
Re: power converter charger?
Postby fishboat » Wed Nov 27, 2019 7:06 am
Some discussion(someone here directed me to this..don't remember who..):
http://www.smartgauge.co.uk/chargesize.html
After lots of research, I netted out with an IOTA DLS with IQ4 built-in. 4 stage & allows charge voltage adjustment. Seems to be working very well.
https://www.iotaengineering.com/12vdc.htm
fishboat
Postby RJ Howell » Wed Nov 27, 2019 7:56 am
tony.latham wrote:I'm scratching my head on why you want to convert 110 volts to 12 volts when you have a battery.
I get why it would be a good thing to have a charger cooking away while hooked up to shore power. A smart charger would cost about $60 and you could select FLA or AGM...
Educate me?
I'm on the same path. I have no Microwave/AC, so I have no requirement for 110v power. If indeed I would require, then extension cord would be my fall-back. I also do not 'Glamp' nor stay at a place more that 3-4 days before traveling on. I can easily re-charge with my B to B charger while traveling (if my solar didn't keep up).
I can only figure it if you Glamp. I only get it if you stay for longer terms at a place and require high amperage.
RJ Howell
Images: 36
Postby Wellcraft290 » Wed Nov 27, 2019 8:18 am
Tony the reason I would like the converter charger is so while hooked to shore power the converter will power all the 12v items instead of the battery and also charge the battery/s with the overflow power.
save on battery drain cycles when I have access to shore power.
Wellcraft290
Postby tony.latham » Wed Nov 27, 2019 9:40 am
...save on battery drain cycles...
That makes sense. Is this going in a teardrop?
Postby Wellcraft290 » Wed Nov 27, 2019 1:36 pm
more of a square top. going to do steel frame with wood skin and the monstaliner
Wellcraft290
