iconicflux wrote:Have a look at the Norcold Polar line. Their documentation says the 12v 8cu/ft fridge pulls .93A.
featherliteCT1 wrote:Last week, my Walmart sourced Arctic King 1.1 cu ft Upright Freezer, 120v, with an add on temperature controller to cycle my 700 watt inverter, to cycle the unit on and off, in order to maintain 39 deg F., in 80 degree ambient temperature, averaged .75 AH, over a 24 hour period. I am very pleased with the energy use and performance.
featherliteCT1 wrote:Yes, that is the link to the Arctic Freezer I bought from Walmart. Here is the link to the Renogy 700 watt pure sine inverter I bought in April 2020, for $130; now it is only $117.
https://www.walmart.com/ip/Renogy-700W- ... lsrc=aw.ds
If search mode is ‘on’, the power consumption in no-load operation is decreased by approx. 70%. In this mode the Compact, when operating in inverter mode, is switched off in case of no load or very low load, and switches on every two seconds for a short period. If the output current exceeds a set level, the inverter will continue to operate. If not, the inverter will shut down again.
