Wiring Tail lights-right is dim
Re: Wiring Tail lights-right is dim
Postby twisted lines » Wed Nov 03, 2021 4:01 pm
Capebuild wrote: One thing that I realized is the 7 pin connector I installed does not seem like it has a typical wiring layout (image attached). So this may be resulting in some incorrect wiring hook ups.
That's a Understament :lol:
Don't Buy The sTARDerd RV one ! :?
Racking up; And Rapin foam
twisted lines
Postby western traveler » Thu Nov 04, 2021 11:37 am
Just to be clear.
I think the pins are standard at the TV. It’s the colored wires that are not standard.
I plugged the pigtail into the TV and used the probe that Woody has pictured to identify each wires function.
western traveler
Images: 264
Postby tony.latham » Sun Nov 07, 2021 10:03 am
For some extra-extra stupid reason...
Postby Tom&Shelly » Sun Nov 07, 2021 11:32 am
tony.latham wrote:For some extra-extra stupid reason...
Yep, same pin functions, different colors. Back at some time in the past, one fellow did it one way for campers and somewhere else, some other fellow did it another way for cargo trailers, and somehow the two evolved to be "standards" independent of each other. Or something. :?
Good thing the pin functions are the same though. When I wired our tear, I used a separate 10 gauge cable (2 wires) to charge the battery, and used a 6 wire cable for the other functions. (Later decided to use a separate 2 wire cable for the brakes too.) Then, for the lights in the hatch, I used another 6 wire cable, BUT, the wire colors were slightly different from the 6 wire cable running through the rest of the tear. (And one of those wires was for the dome light, which of course is on a different 12 volt system than the safety lights.)
Luckily, the electrons don't care about the color of the plastic around the wire! But, although my memory is good, it isn't very long, so I bought a bunch of heat shrink of different colors (I know, I said that above--hah! Bet you all thought that was part of the memory not being very long!) Anyway, because I used screw type terminal strips, and soldered to the ring joints, I needed heat shrink to cover the solder joints anyway. If you crimp, you can still put heat shrink over the plastic protecting the crimps.
To me, +12 volts should be red, and ground should be black, so I used that for both this system and our 12 volt system for the tear internal lights, fan, etc. I didn't use purple, so I must have used the color codes on the right for most of the rest of the wires. I do remember duplicating red, for the stop lights as well. But then, I added a little box that takes the turn and stop signals, and breaks them out for separate turn signals and brake light. Out of that box, I used some dual color heat shrink.
The point is to take an otherwise very confusing system and make it so it makes sense to you.
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
Postby twisted lines » Sun Nov 07, 2021 12:46 pm
Easy to find ; Two Adapter's.
If you have one of each it helps.
Someone at work would actually rewire the trailer if they borowed it.
It make's perfict sense; When someone wires the brake's wrong :thinking:
twisted lines
Postby Squigie » Sun Nov 07, 2021 1:52 pm
I find that some trailers just spontaneously rewire themselves if they sit long enough.
For example:
My crappy cargo trailer only gets used for runs to the dump (where it will eventually be left, one day). I use it maybe twice a year.
Every single time I hook up to the trailer, the wiring is wrong.
I am the only person that has touched that trailer in like 8 years.
Yet, every time I use it, I have to rewire the brake lights.
Last time I used it, I was fed up.
I grabbed some fresh wire and a suitcase connector, and did this: :ok:
(I believe I had to fix the ground, too.)
Squigie
