Solar: Trying to decide charge controller location
Re: Solar: Trying to decide charge controller location
Postby immped64 » Thu Aug 08, 2019 7:55 pm
Hi Tim,
In this case I am looking to remove material instead of adding. I can't slide the tire free or mount the tire because of interference with the 2 bolts. It would actually help if I could knock off a little of the bolt length but it probably wouldn't be enough to give the clearance I need.
What I am thinking is that I would like to cut off a little length to the horizontal mount and have it welded again.
immped64
Images: 19
Postby edgeau » Thu Aug 08, 2019 11:32 pm
I have a simple thought. If it is the bolts that stop the Tyre removal, remove the welded on bolts. Drill holes in the backing plate in the same spot and use ordinary bolts. Then once you have undone the nuts you can get the bolts out of the way.
Sent from my Pixel 3 using Tapatalk
edgeau
Postby immped64 » Fri Aug 09, 2019 7:12 am
Edgeau: That sounds like a great idea!
It may be a bit tricky to remove the welded on bolts but otherwise that would give all the clearance I would ever want.
I then would go to the local hardware store and find a replacement bolt and possibly a washer to tighten the opened up gap.
Thanks a lot!
immped64
Images: 19
