DoctahDeane wrote:Tony - your book, p. 116 -> you show your nice instrument cluster. I have a nice piece of cherry wood I plan to use for something similar. How did you do the cutouts for the individual gauges? Did you use a jigsaw, or perhaps a plunge router?
with a fine-toothed blade in the jigsaw.
Thanks, bud for all the advice.
One strange thing...coming into the under trailer box were two separate wire strands. Most were red/white and so easy connection to fusebox for the lights and fan.
The other wire stand has three wires inside the sheath - green (ground, obviously) and white and black. My assumption was that both the green and the white ought to go to the negative side of the fusebox and the black is hot. Yes, have a 7.5A fuse in the right slot. No juice.
I believe this wire stand is for the standard outlets (one inside and one in galley) but considering i did not build this trailer...I did switch the white and black with no success.
bdosborn wrote:Careful, green white and black wires in a sheath are 120v.
DoctahDeane wrote:My assumption was that both the green and the white ought to go to the negative side of the fusebox and the black is hot. Yes, have a 7.5A fuse in the right slot. No juice. I believe this wire stand is for the standard outlets (one inside and one in galley) but considering i did not build this trailer...I did switch the white and black with no success.
tony.latham wrote:DoctahDeane wrote:Tony - your book, p. 116 -> you show your nice instrument cluster. I have a nice piece of cherry wood I plan to use for something similar. How did you do the cutouts for the individual gauges? Did you use a jigsaw, or perhaps a plunge router?
Good question.
The faceplate is 1/8" Baltic so it was easy to fit everything –-the gauge snapped right into place.
I cut the round holes with Forstner bits and the rectangles with a fine-toothed blade in the jigsaw. I recall a bit of Dremel work for fitment but since the ply was thin, it was an easy job.
Here's the backside:
I'll run 14GA wire to the battery.
tony.latham wrote:I'll run 14GA wire to the battery.
I used 12 AWG. And had them on hand. It may not be FAA approved but you can double that piece of exposed wire and crimp over both pieces.
DoctahDeane wrote:tony.latham wrote:I'll run 14GA wire to the battery.
Yeah, makes sense. Thanks, Tony
I know you are not supposed to go below 50% capacity with these deep cycle batteries. So, what number am I watching out for?
