FAQ:Solar Panel without the Technical Stuff
Re: FAQ:Solar Panel without the Technical Stuff
Postby Shadow Catcher » Tue Nov 27, 2012 8:17 am
Since this was first posted we have successfully used the solar panel and set up on our month long trip to California. This is a 185W high voltage panel feeding into a Morningstar SunSaver MPPT controller and into a 150 AH AGM battery. All of the lights are LED and I used two Computer case fans which use much less power than a Fantastic fan, (conservation is a large part of the equation) but we also power a Waeco refrigerator XM radio and the TV and Laptop. Also part of this equation is monitoring the battery state of charge and I chose a Victron battery monitor because it was small and easy to install and set up.
83771
96129
Postby eaglesdare » Tue Nov 27, 2012 8:34 am
what does this size solar work for? are you all doing this for lights, small fans? my main problem with dry/boondocking type camping is no a/c and not heater. will these solar power panels work for that?
Louella
May the foam be with you.
eaglesdare
Postby GPW » Tue Nov 27, 2012 12:27 pm
probably not .... You’d need big panels and lots of batteries for that ... and an inverter ... $$$$ :o
Postby Junkboy999 » Tue Nov 27, 2012 1:18 pm
eaglesdare wrote:what does this size solar work for? are you all doing this for lights, small fans? my main problem with dry/boondocking type camping is no a/c and not heater. will these solar power panels work for that?
The power coming off the solar panels is not enough to do anything but run small lights and small motors by
itself. I’m talking small motors like you find in cheap toys. What the solar panels does is charge the batteries.
The bigger the panel and higher watt rating the faster the batteries will charge.
The batteries will run your electronics. The more electrical devices you want to run you will need bigger or
multiple batteries. Heaters and AC units will drain a battery pretty fast.
I’m not the expert on this. I just typed this up to help explain what a solar panel will do. I have not seen anyone
run a small 5000 btu window AC unit for more than an few hour off a portable or camper sized solar system. Now a
$22,000 roof mounted system and batteries can run a small one room apartment pretty well.
Here is a system in the youtube link below that can run a window an A/C unit. But with the AC running during
the daytime because it is the hottest time of the day, and the daytime is the only time the system will charge,
you will drain the batteries after a day or two.
http://www.youtube.com/watch?v=rjy5w59GH6Q
Good example of the truth about solar. Guy explained about a refrigerator and AC running or lack of being able to run.
http://www.youtube.com/watch?feature=en ... 0455A&NR=1
There is a youtube video on line and the guy is running a window AC unit all day. He has 20 panels and 9 dc to
ac inverters running, but he never talks about his batteries. I’m guessing he is running 9 batteries banks.
Junkboy999
Images: 52
Postby Shadow Catcher » Tue Nov 27, 2012 2:08 pm
Heat you can do, I am using an Espar diesel heater. AC, either a generator or engine powered AC.
Postby Bogo » Tue Nov 27, 2012 9:24 pm
Solar Air Conditioning is possible, but requires a big solar panel bank. Your TD trailer will need to be insulated or the power requirements will be prohibitive due to the long run times. You will also need much more solar panel area than your TD can provide on it's roof. Look into making a multi-layer slide out type panel holder. When extended it could also serve as a awning to sit under. ;)
For the fun of it, and to prove it was possible, about 5 years ago I researched how to do solar powered air conditioning for the Micro-RV project. I figured out that I would need 8 * 220W panels to just provide for over night air conditioner use plus a 9th panel for all my other uses. My Micro-RV had just enough roof space to hold 3 of the solar panels. What I mean by over night use is 8 hours of use with a 50% duty cycle on the compressor unit. The most efficient units I could find were 12 or 24 VDC powered units made for the trucking industry for cooling cabs while the drivers sleep. Depending on the company they put 4, 6 or 8 Group 31 deep cycle batteries somewhere on the cab and charged them with a larger alternator while driving. They also rip out the engine driven compressor and air conditioner system and only use the DC powered air conditioner while driving as it uses less energy than an engine mounted compressor would use. Fuel savings from that alone will usually pay for the installation in one to two years on a truck that sees 36 hours a week of OTR driving. Going to 24VDC over 12VDC will likely increase the efficiency of the overall system by 6% to 12%. Not much additional efficiency is seen when going to 36VDC or 48VDC. This efficiency increase is mainly due to less conversion losses when stepping up the battery voltage to the voltage needed to run the compressor, but a significant part also comes from less percentage voltage loss in the wiring. For the Micro-RV project I figured on ripping out the pickup's engine driven air conditioner, and replacing the compressor with a 24VDC 200 Amp alternator. I figured that would recharge the AGM battery bank with only 2 to 3 hours of driving. It would also be used to power the air conditioner while driving.
There are two main mounting methods for the truck mounted sleeper cab units. The most common is just like used for RVs. A roof hatch is installed, and the unit is set on top of it just like how a RV unit is installed. The other style of unit is a split unit. One part goes on the outside back wall of the cab. It has the compressor in it, and the exhaust coils. The other part mounts to the inside of the sleeper cab, and has the interior cooling coils and fan. Between the two parts is a tube pair, and all the units I found had precharged tubes and units where you only needed to hook them up and use. No need for charging the system.
Another thing to look for is the use of a thermal expansion valve for controlling refrigerant flow. Units that use a thermal expansion valve over capillary tubes will be much more efficient over a wider range of temperatures. BTW: if your home system uses capillary tubes, switching to a thermal expansion valve will likely pay for it's self in a year or two.
One issue is do you power a regular 120VAC powered RV air conditioner with power from an inverter, or do you get a purpose built DC powered air conditioner. When I explored things, the regular roof top air conditioners powered by an inverter usually used at least half again more energy to run. I think this was because the units were the only standard RV units and weren't all that efficient. I have since seen much more efficient RV units advertised. On the flip side of this is extra energy use with a regular RV air conditioner you can power it directly from a hookup, or from a generator. If you will be often staying at hookup providing camp grounds that may be the better way to go. If you will most often be boondocking, then it may be better to go with the DC powered units. Another advantage of the DC powered units is they often came in smaller sizes which would be better for a small space like a TD. A TD has a similar amount of space as a sleeper cab has.
Another possible source for a small DC powered air condition units are the ones designed for cooling the cabs of earth mover equipment. Retrofit DC units were made for health and safety reasons, then the industry realized they used less energy than the engine powered units and the rest is history. I never could find a place that would sell me a single unit, but that may have changed. It could be an option for somebody who has an in with the industry.
One option I came up with recently was to put in a relatively large 24VDC battery bank, but not fully rely on it to power the air conditioner. The air conditioner is powered by the battery bank, but a generator is cycled on and off to recharge the battery bank back up to 85% when ever it drops below 50%. For use in NPS campgrounds with generator curfews I figured a second control circuit could be based on a timer to force a recharge of the battery bank before generator curfew, and then keep it off over night. Part of the control circuit would be a switch to switch the air conditioner over to the generator when the generator is running. For me a control unit for this wouldn't be hard to piece together, but then I've built industrial controls...
A side effect of going to solar powered AC is with a little increase in system size it is possible to go to electric appliances like microwave ovens, and induction cook tops for cooking. :lol: Even a convection oven could be run from the battery bank. Lighting loads and the recharging of a cell phones or laptops becomes insignificant. Doing the calculations for air conditioning made me also realize that for weekend use, 2 Group 31 batteries charged up at home would provide more than ample power for a full 3 day weekend getaway even with running a 12VDC powered compressor based cooler. No need for solar or recharging from the vehicle.
Have I overloaded your brain yet?
Bogo
Images: 39
Postby Junkboy999 » Wed Nov 28, 2012 9:57 pm
Thanks for the wright up Bogo
Junkboy999
Images: 52
Postby BlackCatRacing » Sun Feb 03, 2013 12:43 pm
What about using heat (propane) to run an AC unit. It is very common in refridgerators. Is this not practical for an AC unit sized for a Teardrop trailer
"Far better it is to dare mighty things, to win glorious triumphs even though checkered by failure, than to rank with those poor spirits who neither enjoy nor suffer much because they live in the gray twilight that knows neither victory nor defeat."
Theodore Roosevelt...
BlackCatRacing
Postby Shadow Catcher » Sun Feb 03, 2013 3:38 pm
I have been looking at an absorption AC unit and while it is possible the level of complication and the difficulty in making it work efficiently. One area of inquiry that shows a bit of promise is the Crosley IcyBall http://crosleyautoclub.com/IcyBall/crosley_icyball.html
http://crosleyautoclub.com/IcyBall/Home ... Built.html Plans to build one your self
The idea is that you charge the ball with a heat source Note in this case it is a Coleman single burner multifuel stove, and then it gives off cool for up to 24 hours. What is not stated is the effective BTU's
Postby RandyG » Thu Oct 10, 2013 2:08 pm
I have found probably the cheapest 100w solar panels available, Renogy on amazon. Less than $200 for 100w is pretty good.
Randy
RandyG
Images: 115
Postby bdosborn » Thu Oct 10, 2013 3:34 pm
RandyG wrote:I have found probably the cheapest 100w solar panels available, Renogy on amazon. Less than $200 for 100w is pretty good.
Solar blvd seems to have the best deals lately, better than Amazon
100 watt panel
Images: 767
Postby RandyG » Thu Oct 10, 2013 5:00 pm
Thanks Bruce, thats another option. The ones on amazon come with a controller and some have free shipping. So its about even, but your link above has more specs on the products. I like to have all the details before purchases. Ahhh, decisions.
Randy
RandyG
Images: 115
Postby Shadow Catcher » Thu Oct 10, 2013 6:01 pm
We now have more experience, eight days on the north shore of Lake Superior Provincial park in a shaded camp site with maybe one hour a day with no shade on the panel. The panel, 185W is a 66 cell high voltage and produces usable current from sun up to sun down. We powered the LED lights, pump, TV/DVD (one night) XM radio, ignition for the water heater, case fans and the big one the refrigerator. We lost a little ground each day but by the end of eight days we were are 64% state of charge. It all works very well.
109120109118
Postby Madmike8 » Thu Oct 10, 2013 9:31 pm
Shadow Catcher wrote:We now have more experience, eight days on the north shore of Lake Superior Provincial park in a shaded camp site with maybe one hour a day with no shade on the panel. The panel, 185W is a 66 cell high voltage and produces usable current from sun up to sun down. We powered the LED lights, pump, TV/DVD (one night) XM radio, ignition for the water heater, case fans and the big one the refrigerator. We lost a little ground each day but by the end of eight days we were are 64% state of charge. It all works very well.
109120109118
I'd say that's positive test! Thanks
It's not about the Destination, It's all about the Ride!
Madmike8
Postby eggsalad » Mon Oct 28, 2013 6:55 pm
What about battery/solar systems on a MUCH smaller scale?
My "battery pack" consists of 2@ 6v 12AH batteries wired in series, for a combined total of 12v 12AH. I like them because they are small and free (out of the recycle pile at work).
The whole system draw is 0.05A for the LED lighting, and 0.3A for the fan. Some quick math tells me I'm not going to need a whole pile of solar panels to keep a charge! A 25W panel gives off 2 amps, right? So 6 hours would be the max charge I'd need for totally depleted batteries?
Seems cheap enough, or can somebody tell me where the errors in my figures lie?
eggsalad
