How to drill for a self-tapping metal screw for ground wire?
Postby kayakrguy » Thu Jan 04, 2007 10:15 am
Folks,
I need to attach my electrical ground to my trailer frame. I know the hitch has a self-tapping screw for the car wire ground for the running and brake lights. I am mounting electrical in the rear and would rather not have to rub ground wire all the way to the front. But, I have never drilled for self tapping screws...does it require a special drill bit?
Help appreciated!
Thanks,
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Postby halfdome, Danny » Thu Jan 04, 2007 10:30 am
Generally a self tapping screw doesn't need a predrilled hole. For example when putting together aluminum gutters and down spouts. Since you are screwing into steel you'll need to use a high speed drill bit (common drill bit) and size the drill bit to the size of the shank of the screw not counting the screw threads, I would size it a smidgen larger too. I would scrape or better yet grind off any paint and use a large head screw for best contact for your ground. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby kayakrguy » Thu Jan 04, 2007 10:45 am
Thanks, Dan
Jim
Edmund Burke
kayakrguy
Images: 195
