Installing a "Hard Start Capasitor"?
Postby Gerdo » Tue Jan 23, 2007 10:20 pm
Does anyone know where to get and how to install a "Hard Start Capasitor" in a window Air Conditioner?
Gerdo
Images: 156
Postby Creamcracker » Tue Jan 23, 2007 10:35 pm
Is that something like a "Flux Capacitor".... now let me get the DeLorean manual.... :D
Creamcracker
Teardrop Graduate
Images: 142
Re: Installing a "Hard Start Capasitor"?
Postby Kevin A » Tue Jan 23, 2007 10:42 pm
Gerdo wrote:Does anyone know where to get and how to install a "Hard Start Capasitor" in a window Air Conditioner?
This link might be of some help.
http://www.inspect-ny.com/aircond/aircond15.htm
Kevin A
The other guy
Images: 289
Postby Podunkfla » Tue Jan 23, 2007 11:51 pm
Here's some more good info:
http://www.davewilson.cc/AirConditioning/
scroll down to: Air conditioning compressor problems...
http://www.toad.net/~jsmeenen/
These are mostly related to central air units, but window units
pretty much work the same way. Hope this of some use to you. :thumbsup:
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby Dooner » Wed Jan 24, 2007 12:13 am
Are you adding a hard start capacitor or replacing a bad run capacitor?
Dooner.
TED NUGENT FOR PRESIDENT!
Dooner
Images: 69
Postby coonrebel » Wed Jan 24, 2007 12:25 am
In Denver ,I have used Tullar Electric Motor Services 3868 Tennyson St. Denver Co.80212 303-458-0824. I have known the dad from 1970 before he passed away and now his son is running it . He knows a lot about electric motors.
coonrebel
Images: 186
Postby Dooner » Wed Jan 24, 2007 12:57 am
Here is a diagram. Depends on how your unit is wired. If there are two caps or one. If this doesn't look like what you have, let me know.
A hard start capacitor would wire up where the H and C are on the compressor cap of either one. The actual capacitor does not usually have letter markings. You'll have to trace the wires.
Dooner.
Dooner
Images: 69
Postby Dooner » Wed Jan 24, 2007 1:08 am
I used to live in Littleton. But had a Golden mailing address on Wide acre rd. I have a relative that still lives around that area. Her backyard looks at the big hill where they built the mall there.
I worked in Broomfeild at Cooper's heating and cooling.
Is Moose Hill still open. When I left, they were building another one. I miss eating at that place. The best mexican food ever.
Mostly miss seeing those beautiful mountains every morning. :(
Dooner.
Dooner
Images: 69
Postby SkipperSue » Wed Jan 24, 2007 7:55 am
It's no problem installing a hard start capacitor to a window unit, I've done it here at work many times. The hardest part is getting the unit opened up and find a place to let it lay. I'd put the largest one I could fit in there.
Skipper
SkipperSue
Images: 114
Hard start kit
Postby Woodyperk6 » Wed Jan 24, 2007 9:20 am
Call an air conditiong parts house or an appliance parts house. Ask for a hard start kit. You need to know the BTU rating of the window unit to get the properly rated hard start kit. They should have a two wire kit with a wiring diagram to show where to hook-up the wires. Make sure the power is off or the unit is unplugged befor you install the kit. Hope this helped you some.
Woody
Woody & Tammy
One day closer.
Woodyperk6
Images: 5
Postby bdosborn » Fri Jan 26, 2007 8:55 pm
Images: 778
