Son, You Need Protection
Postby Sierrajack » Sun Apr 15, 2007 7:56 am
I know this has probably been asked before and I have searched but can't quite come up with a good answer.
My 110 volt circuit will have one GFCI in the galley and a power strip with circuit breaker in the cabin. Is it necessary to also have a seperate circuit breaker panel?
Our local "big box" store has circuit breaker panels about the size of a shoe box, can anyone suggest something more compact to fit within the confines of a TD?
I would like to have circuit protection with the GFCI and power strip just to be on the safe side.
Sierrajack
Images: 41
Re: Son, You Need Protection
Postby Steve_Cox » Sun Apr 15, 2007 8:54 am
Sierrajack wrote:I know this has probably been asked before and I have searched but can't quite come up with a good answer.
$88 (Ain't cheap)Click Here Surface mount and reverse polarity safety light/trip
Steve_Cox
Images: 196
Postby madjack » Sun Apr 15, 2007 9:01 am
SJ...goto www.waytekwire.com and look for "circuit breakers>>>panel mount"...they have some VERY nifty pushbutton circuit breakers from 10 to 40 amps...about the size of a paper matchbook for under 3 bucks apiece...we used 'em and were very satisfied...we made a panel to mount them out of some scrap formica that we painted black...
Postby Endo » Sun Apr 15, 2007 10:54 am
I used this:
Description:
GFCI Protected Quad (4) Outlet Box
UL, CUL Listed
125V / 15 A
Right Angle GFCI Plug
Power On LED
(4) NEMA 5-15 R Outlets
Separate Covers for Each Outlet
6 Ft.,12/3 Awg SJTW Cord15 Amp Circuit Breaker
It is a GFCI, circuit breaker and quad outlet in one nice little package. I know Mike and others have used something similar. Available at Lowes.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Miriam C. » Sun Apr 15, 2007 11:28 am
Your circuit breaker needs to be in front of your GFCI for it to be protected. Your incoming line can be the breaker/GFCI power strip and everything plugged into it will be protected.
Postby Sierrajack » Sun Apr 15, 2007 5:22 pm
Thanks everyone, I appreciate you!!
Madjack - Those panel mount CBs are exactly what I've been looking for.
I'll order a couple tomorrow when Wayteks website is up, apparently they have some problems today.
Endo - No Lowes here, Menards has a monopoly.
Miriam - yep, the first thing the incoming power touches is the circuit breaker.
Sierrajack
Images: 41
Postby madjack » Sun Apr 15, 2007 6:51 pm
Waytek has been physically moving locations and there site has been temporarily down while the move is completed.....
