Harbor Freight trailer electrical gremlin
Postby ahjones3 » Sun Nov 21, 2004 3:10 am
I just finished wiring up the lights for my trailer. I used a jumper battery to test everything out before I installed the floor, and everything worked fine except for the right turn signal/taillight. It wasn't as bright as the left one. I'm color blind, so my first idea was that I goofed up the red, brown, green wires. I checked and rechecked every connection. Then I had my Son come check my work. Everything was right, but it still didnt work. Finally he took a hunk of wire and ran it from the stud that holds the tailight to the bracket, and a bare bolt on the frame. TA DA! The 2, 3/8" bolts holding the bracket to the frame that were tightened with an impact wrench didn't provide a good ground. I took off the bracket, reamed out the holes in the frame a little to get off any paint, and put it back together. That did it. I'm new at 12 volt wiring, so maybe this should have been the first thing I checked. I know better now.
Al.
ahjones3
Postby Woody » Sun Nov 21, 2004 10:31 pm
I have had the same problem and it turned out to be a bad ground as well. Simple fixes are the best
Woody
E-mail: tearjerkerfla@bellsouth.net
Woody
Images: 26
Users browsing this forum: troubleScottie and 2 guests
