I'm getting ready to install a small Voyager Stereo Radio/CD in the TD. It is mfg'd for the RV/Van industry & uses 12v power. Comes with complete wiring color codes but no actual installation instructions. Most everything is pretty self evident however, there are three wires for power, one of course is the ground, another says 'battery', & another says 'ignition'. I'm assuming (yeah, I know what that makes me ) that the battery wire is to keep the clock/memory circuits active at all times, & the ignition is to disable the actual radio/CD portion when the unit is installed in a van/RV. My question - since I don't have any 'switched' ignition circuit in the TD, do I connect both power wires to a fused battery terminal, or will the 'ignition' wire be sufficient since it will be 'hot' all the time?
[url][/url]
