Unlike the ole antiquated USA, many countries require separate brake and turn signal lights and it appears Heikki has his tear set up that way, so a 4 wire plug won't work for him . . . . they may not even sell 4 wire plugs in Finland anywayMiriam C. wrote:Heikki, if you are not running brakes you only need a 4 wire plug. YOu can get an adapter for the 7 wire, that will make it simpler. I used a 4 wire flat to hook to my lights in the hatch and am going to use it as a disconect
Alphacarina wrote:Unlike the ole antiquated USA, many countries require separate brake and turn signal lights and it appears Heikki has his tear set up that way, so a 4 wire plug won't work for him . . . . they may not even sell 4 wire plugs in Finland anywayMiriam C. wrote:Heikki, if you are not running brakes you only need a 4 wire plug. YOu can get an adapter for the 7 wire, that will make it simpler. I used a 4 wire flat to hook to my lights in the hatch and am going to use it as a disconect
I am pretty sure though that he needs at least 5 pins (tail, brake, left, right and ground for his application and maybe even one more, if his clearance and tail lights are on different pins . . . . . and from the translation, it appears they might be
My advice would be for him to get some advice from someone in Finland - We could totally mess him up trying to tell him how we 'do it over here'
Don
