Dale M. wrote:Typically these batteries are gel cells and should respond just like any other battery..... Clue here is "battery has been sitting for years"...... Its probably gone bad internally and though it can produce enough voltage to register on meter, it probably has no capacity (amperage) in which to power your lamps... Essentially it probably died setting on shelf...
BrwBier wrote:If its just during the build that you want the light for then skip the battery and just hook up the light to the charger. I have an old jumper pack that the battery shows voltage but will not light a bulb, so I junked the jump pack and use the charger for testing light circuits. It puts out 12v and works just great and if and when it fails, just toss it, the battery is already gone.
Brwbier
