by Lesbest » Sun Aug 26, 2007 4:57 pm
Miriam, those lights have a 1157 bulb in them and they have 2 filaments, one minor filiment for the running lights, and the major filament for the brake and turn signal. The minor filament is a 3 watt, the major 37 watts.
Take the lens off one stoplight housing and turn on the parking lights and 4 way flashers. That excites everything in the unit, now look at the bulb and if the minor filament is changing in intensity as the major side tries to light up you have found the likely problem--a bad or poor ground. To check it run a jumper wire from the housing to the frame, or the truck and see if the problem changes, if it does and gets better then you will have to track down where the ground disappears or will have to supplament it with another. Remember you can never have too many grounds.--except on the hot side, then one is too many.
Hope this helps, Les
Music is like chocolate.......you can't really enjoy it unless the rappers are gone.
