Hi folks,
Many moons ago I posted a topic about mounting a license plate light.
One central conclusion by members was that the BEST WAY TO GROUND was to have separate grounding wires from each load to a grounding bar.
Here are my questions...
1)Since, for example, my tailights and amber running lights have 'internal grounds' e.g. they are designed to be grounded to the frame via the screw that holds them to the frame, I assume grounding these to a 'grounding bar' would involve running a wire from the mounting screw to the bar??
2) The grounding bar--where do you get same? Do you attach it to the frame? And, I assume you run a wire from the bar to the grounding wire to the car? If not, I don't get the point of using a grounding bar attached to the trailer frame with no connection to the car ground--how is that different from grounding to the frame alone?
Light in these dark corners would be appreciated.
Thanks,
Jim
