If a battery is connected to a charger, and the charger is left off, will that put a load on the battery that would drain it over time?
Reason I ask, I'm starting to sketch out the electrical plan, and if an unpowered charger drains the battery I may want to throw a relay into the charging circut, so that if the charger is off, the circuit is open.
Other than hooking up a battery to the charger and checking for a current flow how could you tell? If you read resistance across the charger I'm thinking that anything other than an infinite reading (or very high resistance) would indicate a potential drain.
Thank
