ronaldito wrote:I believe there should be a device to prevent that or build a circuit to detect correct polarity and actuate a power relay to handle the current
ronaldito wrote:I dont believe a simple fuse can protect sensitive electronics, but it sure does blow after the damage has been done... LOL
Larwyn wrote:The best bet is to simply pay attention to what you are doing. Connect it right and you do not need all the trouble, expense and complication of additional protective circuits which can fail and cause the system not to work even when it is connected correctly. I would rather depend on a piece of simple copper wire for power than any solid state device or relay contact. But we are discussing the electrical system on a camping trailer, not the space shuttle, so if the electrical system fails it should not be the end of the world (or even the end of the camping trip).
SomewhereInND wrote:ronaldito wrote:I believe there should be a device to prevent that or build a circuit to detect correct polarity and actuate a power relay to handle the current
Here was the cause of the electrical fire that I described, and why a fuse did not help.
A starter is almost directly wired to the battery, Just one huge fuse and a heavy duty relay between starter and battery. A starter draws a large amount current, at those current levels devices to check for polarity, either don't exist, or are too expensive.
The problem was caused when the starter relay welded shut, making the starter stay on, it took a while for the huge fuse to blow, by that time the starter relay had melted (one of the fire), shorting the ignition system to the starter power supply thru the relay (fire #1), then the ignition system melted (fire #2).
