Been digging for hours and can't seen to really find the information / Best options I need so hopefully someone can provide input.
I currently have a 7'X14" +2Vnose cargo trailer.
I spend about 90 to 100 nights a year at racetracks (I'm a Professional Photographer)
What I'm looking to do is design the Electrical system in the most efficient way possible using things I already have.
What my plan is, Is to have
-2 120AH deep cycle batteries
-a Charger to recharge them (I have a Schumacher 12/6/2amp charger, Would this work instead of using a RV converter/Charger ?)
-Input for a Champion 2000W Inverter generator.
I also have a old Generac 4500W generator which I only want to use if absolutely necessary because it's very noisy and uses a lot more fuel.
The Generator will be run to recharge the batteries and power a desktop computer with 2 23" lcd monitors
(Even though it's supposed to be a true sine wave generator, Would it be a good idea run the computers off a Surge Protected UPS ? )
-I have a 400W and 1000W inverter. The only thing a inverter will be used for is so I can recharge camera batteries without running the generator.
-I also have 60 Watts of Solar Panels to help keep the batteries charged.
-I have a small Danby 5000BTU portable air conditioner that I don't know if I will use or not. Using the AC and the Computers at the same time would likely require using the large generator.
The items that will run on 12V will be
- A Dometic 12 Fridge. It's rated at 3.7 DC amps. Checking with a Ammeter it draws 3.4 Amps. But I'm not sure how to determine the power capacity required for it since it appears to run anywhere from 20% to 60% of the time.
-2 LCD Ceiling Lamps
-2 Computer fans for ventilation
My current thinking is to put a marine 15Amp inlet on the outside of the trailer for the generator. But maybe using a 30 Amp would be better.
A powerbar with 15amp breaker in the trailer.
Plugging the battery charger into the power bar to charge the batteries when the genny is running.
Having all the 12V running off the batteries.
Having the Solar charge controller feeding the batteries directly.
Is this a stupid idea ?
Would I be better off using some kind of some small controller / Distribution panel ?.
I need to do this as economically as possible due to a recent job loss and currently starting 2 businesses.
Sorry for all the stupid question.
Are there and links to wiring diagrams here that I'm missing ?
