I bought this little 18w solar charging kit from my local trailer supply.
http://www.batteryjunction.com/coleman-58033.html?gclid=COacxJ2nub0CFRQS7Aod_kwArQ
Right now the solar panel runs into the charge controller, and the charge voltage from the Tow Vehicle runs straight to the battery. Everything works fine.
Should I run the TV voltage through the charge controller too? That way the battery wouldn't get cooked on a long drive. I believe the solar panel has a diode built-in.
