by working on it » Thu Jul 31, 2014 10:08 pm
I really bought this surge protector primarily for "surge protection". At my house, we have power surges several times a day (so does the neighbor- we share a "weak" transformer on the main line). I have all my electronic equipment at home on surge protectors, and the windowshakers (I prefer them to the central unit!), each have their own. I have had two surge protectors fail, after several years use, so I wanted one to test that had a status display. Why not use it on the trailer? Surely worth the $15. It will tell me at a glance, if it is good or not. For initial park hook-up, I have a receptacle tester/GFCI tester, 50a to 30a to 20a adapters, and a digital multimeter to check with, also. If I misread something, the new unit will make line status clear to me. The Progressive EMS looks to be a better, quick and reliable way to go, but as I am only interested in running the A/C and or main fan on ac current, if I encounter a problem with the pedestal power (110vac), then I'll check the larger amperage supplies. If all are faulty, then its 12vdc for me. No A/C of course, but the AGM battery can power the main fan (via inverter) for a long, long, time. Then I can recharge the battery before the next evening (even if I have to run the truck for power). And then there's my onboard generator; noisy but, if I have to run it, since it was installed to run the A/C, I will, provided that I can park on the fringe of camp (as usual) to keep from creating a nuisance.
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
