AC Hacking a 9,000 Btu Mini Split in trailer or RV
Postby OverTheTopCargoTrailer » Thu Aug 14, 2014 10:01 pm
Does anyone have any experience using a 9,000 to 12,000 btu mini split in RV or trailer ?
Was looking to see if someone had done it.....and has some longer term results ?
These units have up to SEER 27 and supply both heating and cooling
Thanks OTTCT
Last edited by OverTheTopCargoTrailer on Fri Aug 15, 2014 2:52 pm, edited 2 times in total.
Re: AC Hacking a 9,000 Btu Mini Split in trailer or RV
Postby lrrowe » Fri Aug 15, 2014 12:25 pm
I thought I saw some pictures and words somewhere with this being used. I will look around for it. May not have been in TNTTT.
This will determine if I am crazy or not.
Bob
lrrowe
Images: 439
Postby lrrowe » Fri Aug 15, 2014 12:31 pm
Here is a you tube story on one. I think this is the one I remember.
http://youtu.be/IHDT5ZEpKkw
Here is a link to my google search with other items listed.
https://www.google.com/?gws_rd=ssl#q=sp ... in+campers
Hope this helps a little.
Bob
lrrowe
Images: 439
Postby lrrowe » Fri Aug 15, 2014 12:50 pm
On page 3 of this Forum there are inputs from the installer in the video. Also, there are discussions by others on split units in this forum.
http://www.fiberglassrv.com/forums/f56/ ... 009-3.html
Bob
lrrowe
Images: 439
Postby OverTheTopCargoTrailer » Fri Aug 15, 2014 2:20 pm
Because all these guys only talk about how it won't work because the travel movement causes
the copper pipes to get hard - break and or leak.....around the compressor ?
sort of like the foam sprayed into trailer walls - MYTH of - not working 500 times, however its not based on real experience.
The you tube guy video has his kids screaming in the video non stop & no on the road usage results... :thinking:
he is also using a cheapo $399 unit with no heating & NO INVERTER !!
posted June 2013 - no follow up however ?
Last edited by OverTheTopCargoTrailer on Fri Aug 15, 2014 2:51 pm, edited 1 time in total.
Postby lrrowe » Fri Aug 15, 2014 2:33 pm
Did you check the one forum, page three, I listed above your post. That same guy commented on his there.
Bob
lrrowe
Images: 439
Postby OverTheTopCargoTrailer » Fri Aug 15, 2014 2:50 pm
Yea - he does not say to much in the comments....BUT he did say he drives with it on ?
since it only works on shore power per him - not sure where he gets the power from while driving ?
Postby lrrowe » Fri Aug 15, 2014 3:11 pm
Picky, picky. That is just a formality.
Bob
lrrowe
Images: 439
Postby OverTheTopCargoTrailer » Fri Aug 15, 2014 8:46 pm
Mr Picky Picky
What say yee
7 x 18 trailer , mini split SEER 20 - 9,000 Btu heating & cooling, 675 watts running max
5 hour run time - interior temp 76 , exterior temp 84
What is the calculated power usage ?
:thinking: :thinking: :thinking: :thinking:
Last edited by OverTheTopCargoTrailer on Sat Aug 16, 2014 9:04 am, edited 1 time in total.
Postby lrrowe » Sat Aug 16, 2014 7:07 am
:scratchthinking:
Bob
lrrowe
Images: 439
Postby OverTheTopCargoTrailer » Sat Aug 16, 2014 9:04 am
Math hint
Standard 13,000 Btu roof top RV AC. Unit uses 1,300 watts at full power
So 1,300 watts x 5 hours = 6,500 watts at full power or 6.5 kw
Question therefore :
Postby OverTheTopCargoTrailer » Sun Aug 17, 2014 12:51 am
I'm still a little confused, I don't get it at all ? :thinking: :thinking: :thinking:
You all think nothing & will drop $900 on a new roof AC with 13,000 btu - SEER 10 maybe, cooling only , sucking 1,300 watts & needing a big LOUD BELCHING - 4k genset to crank it up sucking mega gas :x :x
You can't even sleep running the genset unless your deaf ?
Throw in a few extra bucks more to get a mini - SEER 20 for heating & cooling
Uses 50% less power, gen set is 50% smaller, use 50% gas or diesel , super silent running mini
I don't see the downside to the mini split ?
WHAT THE HELL AM I MISSING :thinking: :thinking: :thinking:
Postby jstrubberg » Tue Aug 19, 2014 1:08 pm
Better yet, run a window unit and a cube heater, keep 2/3'rds of your money and half the power requirement.
No one here needs 9k BTU's of cooling. No one.
jstrubberg
Postby MtnDon » Tue Aug 19, 2014 1:24 pm
How can you calculate theoretical power use w/o knowing the heat gain/loss through the walls/roof/floor/windows, or the actual run time ? The assumpyion being that the split mini will not run constantly once the interior has cooled,
The split mini will use less power than a conventional A/C because it is more efficient. If you have some real life data for a conventional system, then it should be relatively easy to compare SEER numbers to come up with an approximation that should be good enough for guesstimating.
MtnDon
Images: 24
Postby OverTheTopCargoTrailer » Tue Aug 19, 2014 8:40 pm
Hi MtnDon
Check your PM 8)
Thanks for following :thumbsup:
