I have built an a frame style popup camper, just did a waterproof camping test last week. Everything looked good. I am currently working on installing my 12 volt system. I plan on using an AGM 12 volt deep cycle (10 feet from panel), 20 amp circuit breaker (6" from battery), master kill switch, parallax 12 circuit fuse board with ground bus (all circuits will be 5 amp fuses), and a variety of 12 volt powered accessories, fans, lights, stereo etc. I calculated that maximum draw on my accessories is 19amps. All led lighting really helped out here. I used #10 AWG wiring for ground and hot leads to each device with a maximum 14 foot run. I plan on using zip ties to tidy all my wiring after the fact.
I have a few questions does my diagram look correct as wired? Do I need to run a second ground to my frame from the fuse panel or just grounded from the battery? Do i need to use grommets or something in my walls where I have drilled through the wall supports? I have included an example image of this
