Splice connectors and common ground wire
Postby abqlloyd » Wed Sep 10, 2014 8:45 pm
I have ordered my fuse box and plenty of other parts for my CTT. I had a discussion with a mechanic friend who said to avoid splice connectors for the ground at all costs. I was actually debating on whether to run separate ground wires back to the panel for each circuit or possibly tap a common ground wire.
Also the topic of a chassis ground came up. I've read the comments here and there seems to be some debate. I'm leaning toward a ground to the frame after grinding the paint and using some dielectric grease.
Any thoughts on splice connectors?
abqlloyd
Re: Splice connectors and common ground wire
Postby lrrowe » Wed Sep 10, 2014 8:51 pm
My approach, unless I find a reason why not, is to run the ground back to the panel. I am only talking about a 14 foot trailer, so why try to save on wire cost?
Bob
lrrowe
Images: 439
Postby citylights » Wed Sep 10, 2014 9:00 pm
I ran dedicated grounds to all my devices. I did not ground my trailer frame.
citylights
Postby GuitarPhotog » Wed Sep 10, 2014 9:56 pm
I run dedicated ground (return) wires to every light, appliance, and outlet. They all terminate on the Ground Bus terminal strip. Then that is connected to battery minus (-).
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby bobhenry » Thu Sep 11, 2014 6:13 am
GuitarPhotog wrote:I run dedicated ground (return) wires to every light, appliance, and outlet. They all terminate on the Ground Bus terminal strip. Then that is connected to battery minus (-).
<Chas>
:beer:
Me Too ! all 5 builds.
Images: 2614
Postby abqlloyd » Thu Sep 11, 2014 6:09 pm
I was leaning towards separate grounds. Wire is cheap but it's less cluttered with less wire.
abqlloyd
Postby Toyotamike » Thu Sep 11, 2014 9:58 pm
Get a wire bus strip and mount it near the panel then run 1 wire back to the battery. It keeps everything organized and allows for additions. And they are only like $5 at home depot or lowes.
Toyotamike
Postby George Taylor » Fri Sep 12, 2014 7:52 pm
For safety sake run a bond wire from the ground strip at the fuse panel to the frame.
George Taylor
Postby abqlloyd » Fri Sep 12, 2014 9:14 pm
I chose the BlueSea panel. Common hot and ground with terminals for separate grounds.
abqlloyd
