noseoil wrote:What about provisions for a solar panel? With the PD4045, would a solar panel just go directly through the controller and then to the battery (with its own wiring) run? Not exactly sure how this would work with both systems installed, hooked up & running. If the sun's out and the battery is already charging from solar, what happens if the PD4045 is plugged into shore power? Will they fight or argue, or are they both smart enough not to bother?
