LED Kitchen Bulbs - Troubleshooting Help Needed *Mission Accomplished *
Postby shootr » Thu Oct 16, 2014 11:36 pm
So I wanted to replace the filament bulbs with LED ones to maximize my battery life.
I got two of these, and two others with a flat face for the inside reading lights (which work fine).
For the life of me I can't get them to illuminate in this fixture. They work in the reading light sockets in the cabin, just not here. (And vice versus - the reading light LED bulbs won't work in the kitchen either) I have 12V+ at the socket, no corrosion, etc.
Any ideas? :thinking:
Thanks in advance.
Scott
shootr
Re: LED Kitchen Bulbs - Troubleshooting Help Needed
Postby SLUG36 » Thu Oct 16, 2014 11:52 pm
check the polarity of the fixture. try and flip the positive and negative wires.
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Postby shootr » Fri Oct 17, 2014 12:20 am
SLUG36 wrote:check the polarity of the fixture. try and flip the positive and negative wires.
Thank you! Will try tomorrow evening and post results. :thumbs up1:
shootr
Postby bobhenry » Fri Oct 17, 2014 6:38 am
12 volt is electric in, electric out, the bulbs don't care about polarity.
The 1156 type bulbs have the little ears straight across from each other the 1157 have high low ears. I had a similar problem and had to grind down one of the ears to allow it to make contact.
Images: 2614
Postby Dale M. » Fri Oct 17, 2014 7:58 am
bobhenry wrote:12 volt is electric in, electric out, the bulbs don't care about polarity.
This statement is ok for incandescent (filament) bulbs ...BUT LED's are polarity sensitive, if polarity of power to socket is wrong they (LED'S) probably will not light....
Dale
Dale M.
Images: 18
Postby shootr » Fri Oct 17, 2014 8:02 am
Dale
This. I forgot about the LED requirement for correct polarity - needed someone to nudge my brain. Now hopefully the fixture isn't a pain to get off :worship:
shootr
Postby bobhenry » Fri Oct 17, 2014 12:17 pm
See I learned something today !
Images: 2614
Postby shootr » Sat Oct 18, 2014 2:01 am
Good to go, thanks again amigos!
shootr
Re: LED Kitchen Bulbs - Troubleshooting Help Needed *Mission
Postby noseoil » Fri Oct 31, 2014 8:00 am
So now that they're working, how bright it that fixture when it's running? Too much, just right or not enough compared to the old filament bulbs?
137905
noseoil
Images: 669
Postby shootr » Fri Oct 31, 2014 12:34 pm
Whiter than the filament bulbs but just right, not glaring/annoying. I like this light because you turn one or both on so it's always the perfect amount.
shootr
Users browsing this forum: No registered users and 22 guests
