by MtnDon » Fri Dec 05, 2014 10:00 am
Choosing an inverter requires a couple of basic questions and answers, in order to make an intelligent selection.
1. What do you want to run off the inverter, and how long?
2. How much power can the battery or batteries safely deliver?
#1 may not be compatible with the amount of battery capacity available.
Re #1, The maximum watts that would be used at any one time will determine the max continuous output; that is easy enough to total up. However, the choice of power waveform must be made as well. Modified sine wave vs pure sine wave. Some devices like many chargers for tools and other small devices, electric motors, microwave ovens prefer pure sine wave and some will not operate on modified sine wave at all. Things that heat electrically like coffee pots are generally fine on modified sine wave. The more electronics there are in a device the more the reason for pure sine wave power; the life span of the electronics may be better. That's a broad statement, but in the off grid living world it has been found that modern appliances with electronic controls survive better on pure sine wave power. Sometimes you can't tell id the lifespan will be shortened on mod sine wave until the device fails. Regarding most devices with motors; motors run less efficiently on mod sine wave, they create more heat and heat is bad. Heat is also electricity being wasted. Power from batteries is precious and should not be wasted.
Re #2, A battery should never have more than half it's rated capacity used if long battery life is desired. Thats measured in amp-hours. A 100 amp-hour battery therefore should only be used to supply 50 amp-hours of power before recharging. 50 amp-hours at 12 volts = 600 watt-hours. An inverter will waste 10-15% of that as they are not 100% efficient. Take that into account.
Anyhow that a starting point.
