Hi everyone,
This is my 2nd post. I have a 6x12 vnose enclosed trailer that I'll be using for multi-use. Camping, occasional moving of material(construction) and hangar for my giant scale radio control airplanes. Here's what I'm looking to accomplish. I want to be able to run on shore power(plugged in to house and generator) and battery power. This is what I have purchased already:
Yamaha 2400 ishc
coleman polar cub mach 8 9200 btu
PD 4045
2000 watt pure sine wave inverter
2 Trojan t-105 run in series
in-line 200 amp ANL fuse off the battery
CR radio with speaker
32' smart tv (kids love Netflix)
lots of LED strip lights to be ran inside and outside
Marinco 115 volt charger inlet
20 amp generator cord
Other stuff that I'm sure I forgot.
*My biggest questions are what size wire from inlet to converter?
What size cables from converter to batteries?
I only bought a 115volt inlet and not a 30 amp (not sure if I need one)
Battery cable/ground size for batteries and to inverter? The distance from inlet to converter to batteries and inverter will be no longer than 5 feet if that helps.
To ground or not to ground to frame? ( I know it can be a touchy subject)
I want to be able to run the TV off off shore and battery power. Would I need a ATS or is there another way of doing it without swapping plugs?
I have a little experience with AC but it's been over 20 years since I've played with DC and that was limited to hooking up car stereos in my younger days.
I welcome all suggestions to what has worked for everyone or what will work.
Picture would be nice to if you feel like sharing!!
Sorry for such a long-winded post....
Thank you all!!!
Mike
