lashlsufan wrote:Thanks for your time and reply. A few questions:
1. When you say "over fused" do you mean I could consolidate some of the circuits. For example, put all lights on one fuse?
2. I understand what you are saying about the 20A fuses. I will likely use a 10A or smaller on some circuits per your recommendation.
3. What does not seem realistic? The fan being 1A? Maybe I don't understand how those usb charger/ wall outlets work. I looked up a 12v fan and did the calculation. It was 1.3A.
4. The AC and DC will be grounded to trailer frame from what I can understand. Is this incorrect?
You could consolidate a good bit of the loads to just a few circuits. Afterall your 12awg circuits can theoretically carry 16amp constant loads. But its good to leave your loads spread out to multiple circuits as well. Makes for easier troubleshooting/isolating problems and leaves capacity for future additions.
Its a choice for yourself.
I as in your plan, "cig/usb fan" thing indicated to me it incorporated cigarette receptacles as well. Common cigarette plug appliances, lamps fans etc. can draw up to many amps. Perhaps my mistake\ reading??
On the 120vac side of things, The grounding conductor of your shore appliance cord and grounding conductors from your 120vac devices should be connected to the chassis.
DO NOT connect the grounded current carrying conductor of anything to your chassis.
Grounded conductor and
grounding conductor are not the same thing and its HUGELY important one understands the difference.
Grounding the battery negative is good practice but its optional so long as all negatives of your 12v system are wired together through a suitable size conductor then eventually connect to the battery negative.
A trailer chassis is an ideal "suitable size conductor" for this purpose. Of course assumes well done wire connections and continuous conductivity of the chassis members.
