JmsCaverly wrote:What size gauge wire are you guys using for you charging systems. I planing on using a 10ga wire straight from the battery to the connector. Or is that too much?
Without a lesson in electricity basics...
10 awg would work. But...
Bigger is better when it comes to battery charging circuit.
When charging 12v batteries, every fraction of volt lost within resistance of the charging circuit will greatly affect time required of fully recharging.
Perhaps go as large as your connector plug will accept.
Dont forget your ground conductor,
At minimum same size as your battery charging wire, but bigger is better as ground carries also negative current of battery charging and lighting, brakes, etc.
