Are you running your lights INTO the TD, then out, where appropriate? If so, how did you enter the TD, and seal it against water? I have 7 blade connector on my TV. I can either run the lights under neath, and only run the power from TV into the TD, or I can run it all through the TD.
I could put a 7 blade vehicle end connector on the front of the TD, sadly though, I can't find any in white, which my TD is. Thoughts on what you did, or would do?
