Shadow Catcher wrote:I was curious if leaving the TV plugged into the tear would allow the solar panels to charge the TV battery and yes it will, since the PD is on the same circuit it will as well. BUT you need the seven prong plug and wiring to the battery.
Not saying this is a bad idea or concept, might even save TV battery, but my preference would be TV battery disconnected or isolated from tear and "other" charging or use source when unit is parked... I like the idea of a relay/solenoid disconnect operated by TV key control....
Dale
