troubleScottie wrote:I will start prototyping sometime in October. Life gets in the way of fun.
I have been looking at the various bits and pieces -- The switch to drive a latch is easy ( two lines of code and the appropriate connectors ).
The hard thing is getting all the other pieces ie TFT, extra output pins, possible memory expansion and the code for a menu. Starting with a Mega and TFT touchscreen and see how things go.
Actually the most challenging might be how to make this into a non-breadboard solution for a hot, high vibration environment.
friz wrote:TDCM (TearDrop Control Module)
troubleScottie wrote:Actually the most challenging might be how to make this into a non-breadboard solution for a hot, high vibration environment.
friz wrote:Do you think that demand would be enough to warrant design and manufacture of PCB's?
MtnDon wrote:I peek under the bed to see the fresh water level
friz wrote:Some temp sensors for monitoring wheel bearing temps while on the road might be a nice function.
troubleScottie wrote:I believe the Arduino can sample 1,000,000's of times per second.
troubleScottie wrote:My only addition would be to add a tilt detector to stop everything if the stand/solar panel fell over.
bobgbob wrote:I am sure there are a few gadgets that you could implement with a Pi as well.
troubleScottie wrote:... generally running some form of unix/linux.
friz wrote:If you included some accelerometers they could be used to assist in leveling also.
